Online: Stuart
2008 SPORTSTER......OIL FROM AIRFILTER
  • marshy
    marshy
    Hi all , just a question ...has anyone else had problems with breather valves or the seals that go with them . l have oil coming out of the airbox ... not alot but enuff to make me look a bit oily on my right leg. The airfilter is standard and l have not overfilled the oil tank . This leaves the breather valves as the culprit .... but l havent heard of anyone having trouble with them before. Anyone here experienced it before ??????
  • 308bever
    308bever
    are you sure you have not over filled the oil tank? mine is good if it`s on the half way mark of the stick when hot! NO HIGHER THOUGH.
  • Colstah
    Colstah
    I stand ready to be corrected, but I don't think you can overfill the oil tank and cause problems, apart from oil coming out the top of the filler when it gets hot and expands.
    As far as I know, the mark on the dipstick is to show minimum level....
  • marshy
    marshy
    Thanks for the reply, l will try reducing the oil to that level and see if it makes a difference. Never had it happen before though .
  • marshy
    marshy
    Thanks for your reply . In the hand and workshop manuals it states an overfilled oil tank will dispell oil via the airbox . Well at least l think  that's what  l read , better check .
  • 308bever
    308bever
    let us know if that fixes it marshy. good luck (((-:
  • marshy
    marshy
     . I have found the culprit and am grateful to all those who replied. As it turns out ....the front right fork seal had gone and was slowly leaking oil onto me and the motor . It was slow at first but as the seal wore more ..l wore more oil.... fork oil to be precise. Regards
