Online: Stuart
DEAD BIKE
  • Emperor15
    Emperor15
    Hi guys,
    Hows it going? This might be a fairly obvious question but I'm unsure. Went to go for a ride just before and turned the key and the alarm started going nuts for 30 seconds then would turn off and come on again 30 seconds later. Now the bike is completely dead, no alarm, no odometer display.Flat battery? Anything else? The bike is a 2009 883 custom. Any help is much appreciated.
    Thanks,
    Robbie
  • 308bever
    308bever
    my guess, time for a new battery for the security fob and or the bike battery too.
  • sag57
    sag57
    Yes l believe beaver is on to it , you need to replace the fob battery , these need to be replaced every 2 years , otherwise you've seen the result
  • Emperor15
    Emperor15
    Thanks for the responses guys. Much appreciated. I'll get onto it.
    New bat for fob
  • Frosty57
    Frosty57
    +1 To all the above, got a mate that just went through the same thing. Good thing is it's an easy fix.
