hey guys i have a 2013 sportster iron need help badly, changed handlebars to clipons pinched the left hand indicator cables purple and orange ones (ones goining to the left turn signal button) blew the fuse that was appropriate for that and the indicator still does not work even with the the wirs connected back together ect! Right works and hazards just the front left and back left will not flash at all on (left signal) on (hazard) and when alarm activates
can some one help me out please
Starting with the obvious - have you checked the globe? Swapping the front globes will test it out for sure. I realise the rears are the combined LED units, so no globe swapping there...TC
Try disconnecting the battery for a while and see if that works.
Like I said, get a multimeter and turn it onto the setting that beeps when you touch the probes (the metal part of the "sticks" together. Put one probe at one end of the wire near the blinker, then trace the wire back and stick the second probe on the next connector along. If it beeps it's probably okay, if it don't, it probably has a break somewhere - just make sure you test one wire at a time and there's no circuit boards or whatnot in between.
And while you're at it check the wires are still connected properly to either end. If its crimped enough to cause a break it can also break at whatever its connected to.
