diagnostic codes
  • carl65
    carl65
    G'day all
    im looking for the diagnostic codes for a 2011 street bob (stock) if anyone can help
    Cheers Carl
  • Nomada
    Nomada
    30 secs on google found this.
    http://www.fuelmotousa.com/harleycodes.html
  • gidgi
    gidgi
    google is your friend
  • Mr_Bean
    Mr_Bean
    If you have a smart phone you can download an APP that has them all
    1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
    2- Push odometer reset button in & hold.
    3- Turn ignition switch to Ignition and release odometer reset button. Background lighting should illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word “diag” should then appear.
    4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
    5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
    P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carbureted])
    S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
    SP = speedometer
    T = tachometer
    6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC’s the code will be displayed or the word “none” will appear if there are no DTC’s. Push the odometer reset button again to view additional codes if they exist.
    7 - Record the codes.
    8 - If DTC’s are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
    NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC’s again by repeating steps 1 to 9. If the code is current it will reappear.
    9 – Press and release the odometer reset button to continue to the next module.
    10 – Turn Ignition switch to OFF.
    DTC FAULT CONDITION MODULE
    B0563 Battery Voltage High TSM/TSSM
    B1004 Fuel Level Sending Unit Low Instruments
    B1005 Fuel Level Sending Unit High/Open Instruments
    B1006 Accessory Line Overvoltage Instruments
    B1007 Ignition Line Overvoltage Instruments
    B1008 Reset Switch Closed Instruments
    B1131 Alarm Output Low TSM/TSSM
    B1132 Alarm Output High TSM/TSSM
    B1134 Starter Output High TSM/TSSM
    B1135 Accelerometer Fault TSM/TSSM
    B1151 Sidecar BAS Low TSM/TSSM
    B1152 Sidecar BAS High TSM/TSSM
    B1153 Sidecar BAS Out of Range TSM/TSSM
    P0106 MAP Sensor Rate of Range Error Carb
    P0107 Map Sensor Failed Open/Low Carb
    P0107 Map Sensor Open/Low EFI
    P0108 Map Sensor Failed High Carb
    P0108 Map Sensor High EFI
    P0112 IAT Sensor Voltage Low EFI
    P0113 IAT Sensor Voltage Open/High EFI
    P0117 ET Sensor Voltage Low EFI
    P0118 ET Sensor Voltage Open/High EFI
    P0122 TP Sensor Open/Low EFI
    P0123 TP Sensor High EFI
    P0261 Front Injector Open/Low EFI
    P0262 Front Injector High EFI
    P0263 Rear Injector Open/Low EFI
    P0264 Rear Injector High EFI
    P0373 CKP Sensor Intermittent Carb
    P0373 CKP Sensor Intermittent EFI
    P0374 CKP Sensor Not Detected Carb
    P0374 CKP Sensor Synch Error EFI
    P0501 VSS Low Carb
    P0501 VSS Low EFI
    P0502 VSS High/Open Carb
    P0502 VSS High/Open EFI
    P0505 Loss of Idle Sped Control EFI
    P0562 Battery Voltage Low Carb
    P0562 Battery Voltage Low EFI
    P0563 Battery Voltage High Carb
    P0563 Battery Voltage High EFI
    P0602 Calibration Memory Error Carb
    P0603 EEPROM F
    Or this listing
    Here is the complete list.........
    These will also work on the 07 & 08 bikes.
    The IM (instrument module) is capable of displaying DTC's (diagnostic trouble
    codes).
    Speedometer Self Diagnostics: The speedometer is capable of displaying and clearing
    speedometer, tachometer, TSM/TSSM and ICM/ECM Diagnostic Trouble Codes (DTC).
    to P, etc.)
    [Carbureted])
    SP = speedometer
    T = tachometer
    On models not equipped with a tachometer "No Rsp" will appear when the
    tachometer identifer is selected.
    "No Rsp" will also appear if the run/off switch is in the off position when doing this
    proceedure.
    "BUS Er" Serial data bus shorted/low/open/high
    B1122 Right turn output fault
    B1141 Ignition switch open/low
    P0131 Front 02 sensor low (lean)
    P0132 Engine running rich
    P0134 Front 02 sensor open/not responding
    P0151 Rear 02 sensor low (lean)
    P0152 Rear 02 sensor high (rich)
    P0154 Rear 02 sensor open/not responding
    P0501 VSS Low Carb
    P0501 VSS Low EFI
    P0603 EEPROM Failure Carb
    P0603 ECM EEPROM Error EFI
    P0604 RAM Failure Carb
    P0605 Program Memory Error Carb
    P0605 ECM Flash Error EFI
    P0607 Converter Error Carb
    P0661 Intake solenoid low/open
    P0662 Intake solenoid high/shorted
    P1001 System Relay Coil Open/Low EFI
    P1002 System relay Coil High/Shorted EFI
    P1003 System relay Contacts Open EFI
    P1004 System Relay Contacts Closed EFI
    P1009 Incorrect Password Carb
    P1009 Incorrect Password EFI
    P1010 Missing Password Carb
    P1010 Missing Password EFI
    P1351 Front Ignition Open/Low Carb
    P1351 Front Ignition Open/Low EFI
    P1352 Front Ignition Coil High/Shorted Carb
    P1352 Front Ignition Coil High/Shorted EFI
    P1353 Front Cylinder No Combustion EFI
    P1354 Rear Ignition Coil Open/Low Carb
    P1354 Rear Ignition Coil Open/Low EFI
    P1355 Rear Ignition Coil High/Shorted Carb
    P1355 Rear Ignition Coil High/Shorted EFI
    P1356 Rear Cylinder No Combustion EFI
    P1357 Intermittent Secondary Front EFI
    P1358 Intermittent Secondary Rear EFI
    U1016 Loss of ICM/ECM Serial Data Instruments
    U1016 Loss of ECM Serial Data, Vehicle Speed, Vehicle Inhibit Motion or Powertrain
    Security Status TSM/TSSM
    U1064 Loss of TSM/TSSM Serial Data Carb
    U1064 Loss of TSM/TSSM Serial Data EFI
    U1064 Loss of TSM/TSSM Serial Data Instruments
    U1097 Loss of Speedometer Serial data Carb
    U1097 Loss of Speedometer Serial data EFI
    U1097 Loss of Speedometer Serial data TSM/TSSM
    U1255 Missing Message at Speedometer EFI
    U1255 Serial Data Error/Missing Message EFI
    U1255 Serial Data Error/Missing Message Instruments
    U1255 Serial Data Error/Missing Message TSM/TSSM
    U1300 Serial Data Low Carb
    U1300 Serial Data Low EFI
    U1300 Serial Data Low Instruments
    U1300 Serial Data Low TSM/TSSM
    U1301 Serial Data Open/High Carb
    U1301 Serial Data Open/High EFI
    U1301 Serial Data Open/High Instruments
    U1301 Serial Data Open/High TSM/TSSM
    2006 models with 02 sensors (Dynas)
    P0131 Front 02 sensor lean for any length of time
    P0151 Rear 02 sensor lean for any length of time
    Above codes can also be set if 02 sensor fails.
    AFR – Air Fuel Ratio
    ATS – Air Temperature Sensor
    BAS – Bank Angle Sensor
    CCM – Cruise Control Module
    CKP – Crank Position Sensor. The CKP generates an “AC signal” which is sent to the
    ECM where it is used to reference engine position (TDC) and speed. Home position
    established by taking readings off the 22 teeth on the alternator rotor.
    DTC – Diagnostic Trouble Codes
    ECM – Electronic Control Module. (The Computer) Computes the spark advance for
    proper ignition timing and fuel control based on sensor inputs (from CKP, MAP & TP
    sensors) and controls the low-voltage circuits for the ignition coils and injectors. The
    dwell time for the ignition coil is also calculated in the microprocessor and is
    dependent upon battery voltage. The programmed dwell feature gives adequate
    spark at all speeds.
    ECT – Engine Coolant Temperature. Sensor also controls the cooling fan relay that
    provides 12 Vdc to the fans.
    EFI – Electronic Fuel Injection
    EFP – Electronic Fuel Pump
    ET – Engine Temperature sensor
    FI – Fuel Injectors
    FPR – Fuel Pressure regulator
    IAC – Idle Air Control actuator
    IAT – Intake Air Temperature sensor
    ISS – Ion Sensing System…detonation detection
    MAP – manifold Absolute Pressure sensor. The MAP sensor monitors the intake
    manifold pressure (vacuum) and sends the information to the ECM. The EMC then
    adjusts the spark and fuel-timing advance curves for optimum performance.
    TP – Throttle Position Sensor
    VE – Volume Efficiency
    VSS – Vehicle Speed Sensor. Used as an input for idle speed control
