Online: Soapbox2627, beaglebasher
missing baffle
  • 12hundge
    12hundge
    Gday all,
    i recently discovered that ive lost a baffle out one of my pipes, im running hooker troublemakers 2into 2, i only have one baffle in coz the other fell out.. i cant seem to find these hooker baffles, ive ran the bike with no baffles but will it hurt the bike if one pipe has a baffle and the other doesnt??
    thanks in advance ppl, cheers
  • 12hundge
    12hundge
    I will do bonkerz cheers, but do you think running only one baffle until I sort out replacement is bad for the bike?
    again, thanks for any help..
    I was always told (from people I trust) you want equal (ish) back pressure in both pipes. People I don't know have said otherwise, but I always err on the side of caution. They are some loud pipes I presume, but you could try taking out the second baffle and lollypopping the pipes to lower the noise levels - at least until you get your second baffle..
  • 12hundge
    12hundge
    thanks for the help mate, doesn't seem right only running one baffle, I think ill just get straight onto finding replacement, they are quite loud even with the baffles, without the baffles I get a bit of lag and also fair loud decal popping , cheers
  • terroristone
    terroristone
    Where are you located?
  • 12hundge
    12hundge
    geelong Victoria
  • 12hundge
    12hundge
    Mate, looks exactly like whats in mine, they are the straight cut trouble makers, may be able to see from pic on my profile but to me what youve got look identical..if you have no use for them id be more than happy to sort somthing out mate, muchly appreciated
  • terroristone
    terroristone
    I have only one if you want it. Where r u located?
  • 12hundge
    12hundge
    I would definitely be interested, I'm from geelong, if you wanted to pm me we can sort out how and where I could maybe pick it up from..? Cheers
  • terroristone
    terroristone
    im home all weekend dude, txt or call me and your welcome to come and pick it up.
    Regards Andrew - T1
