Online: tussuck
Opinions on sporty belt drive vs chain, pro's/cons?
  • Jim329
    Jim329
    Hi guys,
    Any options on this as I'm torn between the two..
  • GT 1200
    GT 1200
    You might need to explain? What's wrong with the belt drive?
    I think he means opinions of belt vs chain, not options. Imo the belt is way superior - or at least that's what I've been told over the years. It's biggest seller for me is it's less likely to break without obvious warnings and a lot less liekely (<--WTF KIND OF SPELLING IS THAT?) to damage the bike on it's way out.
    ^ +1 what he said, also no Chain Lube all over your ride.
  • Nomada
    Nomada
    Belt is also quieter and less likely too stretch therfore less time spent adjusting.
  • 883n Harley Convert
    883n Harley Convert
    Belts are better for a number of reasons, but chains just look fucking cool............hahah!!
    You can also run a large wheel/tyre with a chain..............................
  • skirtster
    skirtster
    If you pick up a small stone or something between the belt and pulley it's not going to give you any warning it's going to break. I prefer a belt, less to maintain and quieter
  • Jim329
    Jim329
    Hi guys, thanks for the opinions....food for thought. I just bought my first HD today....awesome. Tell me what you think.
  • 98superglide
    98superglide
    Looks good mate, what did you pay for it?
  • Jim329
    Jim329
    $6600, just got to gat a RWC on Monday then should be GTG....
  • 98superglide
    98superglide
    Good stuff....looks like an 04 -06 sporty?
  • 98superglide
    98superglide
    Xy
  • Jim329
    Jim329
    Good eye 98, she's an '04, planning to make her a little more Matt though pipes etc...but she's my first so for the moment just going to enjoy the ride....
    Chain is stronger, & if it did break ( never broke one myself ) you can carry a joining link. & keep riding if your way out in the sticks. belts just snap, especially if like has been mentioned they get a stone between belt & pully. then you see a black snake in your rear view mirror & your revs go up the bike stops moving. hope your not out in the sticks. chain is the best. but belts are cleaner just can't take as much power & torque as a good chain can.
  • careyman
    careyman
    replacing chains, sprockets meh, belt for me...
    01 Dyna changed from belt to chain in 02 as was riding to QLD to drag race then riding home to Sydney , well got best made in USA sprockets & best chain i could get, 90,000k12 years latter did bottom end in motor went through three cam chain adjusters in motor ( twin cam ) went to gear drive in cams ( like a stock sporty ) but the original chains & sprokets still going strong, saw a lot of snapped belts on the startline drag racing. now bike has new owner & chain still going so are same made in USA sprokets. but if you take the made in asia cheap sprokets they probably wear, if you buy a cheap chain would probably stretch. but i oiled and cheaned chain a lot. but i know guys that did 300,000k on a belt but kept it adjusted & stone free.
    I should have mentioned if you plan to race/drag race I was told always go with a chain over a belt. I believe Krash K above has pretty much covered why.
  • judgelj
    judgelj
    I know someone that has gone from belt to chain on a custom heritage softy
  • BBYHD
    BBYHD
    Resurrecting an old post here, did a search, couldn't find any other related posts....
    Anyone got any more recent opinions/advice/experience with a belt to chain conversion for Sportsters?
    Worth the cost? (what is the cost roughly?)
    Example:
    http://www.zippersperformance.com/chain-conversion-kits-xl.html
    Extra maintenance, unless theres a sealed o-ring chain that suits?
    Thanks guys.
    Chris
  • oneup
    oneup
    i have belt  mrs has chain.. one chain advantage we like is we can use a tow dolly and connect and disconnect the chain easily
