streetbob fuel leak fix
  • kickinon
    kickinon
    2006 streetbob,ive had a fuel leak, just a dampness on the fuel line you could smell & feel when running hand over the line,it worsened to noticable drops on the primary cover , id taken the fuel line off cleaned the area a few times didnt help,,.rang the hd shop, told its common & replacment parts available, l asked whats the issue with it? replied just age & wear can order the parts for you if you want?,told him i'll get back to him after l take mine apart to find out whats up, dont have to take the tank off but you need to remove the filter & fuel pump assembly,(change the paper filter while your at it),, what l found was some very very fine wear marks on the joints,where the fuel lines couple together, not even measurable less than a thou"change both the line in the tank & the line from tank to injector body..there were 3 marks (1shown by the pencil) this is where they touch on the 3 ball bearings when you lift the chrome fitting (tank line) any way the new fitting has 5 ball bearings placed around instead of 3 so its a more stable fit on the (injector to tank fuel line )should last longer this time with the re-designed parts.
  • Daggs
    Daggs
    Thanks for the heads up !
    Happened to my 2007 Street Bob back in 2010.... simple fix
  • kickinon
    kickinon
    yes still have the packages ,,fuel filter part number is 61011-04A.(2pieces in pack)rubber o ring & filter..
    .fuel line part number is 62194-04B (its called check valve body assembly output) on pack..
    fuel line assembly (tank to intake) part number 62349-04F..
  • kickinon
    kickinon
    borisat, cant find the other thread that was up here on the inner primary bearing , did you change it out yet? did you have to purchase new gaskets?
