Online: Wanderer57
Fitting Rear Wheel to 2008 FXDB Street Bob
  • dkanz
    dkanz
    Hi there...could someone please advise on how to refit the rear wheel so it is running true? There are no marks on the swingarm to help with alignment.
    Many thanks :-)
  • Cv ohhh
    Cv ohhh
    There's 2 small holes in the swing arm.You need the axle alignment plugs that go in the axle and then measure from swing arm holes to axle centre plugs
  • robots
    robots
    Hi,
    Make a right angle tool with rubber o ring on it to slide along and measure to make sure both sides correct
    Thanks
    Robots
  • dkanz
    dkanz
    yes Hey thanks guys.....all sorted now, and so easy!   smiley
