Online: B0nes, Wanderer57
Lighting options for a 2011 FLHR
  • BlackRk103
    BlackRk103
    Hi fellas- I currently have the stock  globes in both headlight and passing lights though i would like it to be far brighter. I do not want to spring for the HD LED setup ( yep I'm a tightarse) and am open to any ideas. What do you guys reckon?
  • Deadwood
    Deadwood
    I'm not sure there's too much out there aside from the LED type Daymaker setup. Have a look into a product called 'Truck Lite Phase 7' which is a cheaper option LED and I think it's what Harley are using nowadays anyway, just re-branded.
  • rider
    rider
    Try J&P Cycles for the TruckLite Phase 7 Kit, lots cheaper and in my opinion the Trucklite is a far better unit than the HD (J W Speaker) units.
    Few months ago they were selling the 7 inch headlight and two passing lamps as a kit for under 300 bucks, cost around 50 for postage.
    http://www.jpcycles.com/product/ZZ36773
