Online: WideglidingNZ
lack of spark
  • watcycle
    watcycle
    have recently rebuilt the motor turns over nicely however no spark have swapped out coil pack & crank position sensor with known working ones no joy still no spark have allready checked all the usual causes any ideas
    try angle bank sensor
  • watcycle
    watcycle
    pretty certain it isnt the bank angle sensor as this shuts everything down & the motor turns over only no spark
  • watcycle
    watcycle
    EFI
    Compression check first, if OK then try checking for spark with both plugs fitted, using spare plugs on the leads.
  • terroristone
    terroristone
    Did you happen to change rockers?
    T1
