Online: Fletch1953, obisteve, speedzter
PINGING
  • jocky
    jocky
    Hi fellas,had my bike tunend by lushy couple of years ago.''posted previously''and was fantastic,but now my bike has started pinging all of a sudden.
    starting to get worried,what has changed?.....jocky
  • AJ56
    AJ56
    Possibly bad batch of fuel. What bike? EFi Carby?
  • jocky
    jocky
    hi aj56 2010 wide glide. was thinking fuel meself but its been at least 2 tanks full since it started
    2 tanks from the same place?
  • jocky
    jocky
    yeah have always got my petrol ''bp premium'' from the same place
    I'd try a change of stations and fuel and see what happens.
    Bad fuel , drain as much as you can and fill up somewhere new .
  • Ando
    Ando
    closed or open loop tune?????
    Buggered O2 Sensor perhaps (if its not the fuel)
  • Ando
    Ando
    if its in open loop O2 sensors won't have anything to do with it, if in closed loop its a common thing for tune to go bad, a quick reflash of tune normally does the trick or just set in open loop
  • jocky
    jocky
    had along ride today filled up at a different station pinging has gone must have been bad batch of fuel.
    thanks all for your input.....jocky
    Glad it's sorted.
  • Wimbo
    Wimbo
    It would.
    when they tune them for max effort there's no room for any shit fuel or any changes like slight raised comp thru carbon buildup hot weather bike heavy than it use to be inc rider etc
  • HogBag
    HogBag
    Shit Rob I thought you where a carb guy.
