Online: Ultramick
Removal of light panel strip in dash
  • Hubba
    Hubba
    Hi all I have a softail 09 and purchased a new chrome dash, I've removed the speedo and switches but can't seem to remove the light panel, is thee a trick to it can someone help please
  • rider
    rider
    Pretty sure they same as the dyna, snap into place and held by plastic tabs, barb style, all part of the panel.
    Get behind it and squeeze the two tabs in and it should pop out.
    Think the last one I changed I just used a fine screwdriver and levered it out from the top.
