Online: Ultramick
does anyone know who made my wheels
    Its difficult from the photos to tell what you are trying to show. Has the rim split?  Dont ever put a tube into a tubeless tyre. Your life is worth a lot more than the cost of a replacement rim or a professional repair. More photos may be helpfull
  • terroristone
    terroristone
    Try dragway
    T1
  • fatmatt
    fatmatt
    OK
    so just out of interest, what's the difference between a tubed tyre and a tubless one when the almighty deflate at speed happens.
    why would it make such a difference?
    Generally not a problem running a tube in a tubeless tyre.
    Heat is the main difference, and speed rating should be lowered. Not a fan of running the wrong size tube, but it can be done in an emergency.
    Have a read here: http://www.conti-bike.co.uk/default.asp?pid=26
    there  Dragway  Australia , use these quite often
