does anyone know if I use a FP3 after having used a SERT on my bike, if the FP3 will then lock out the SERT..
I've a Ducati that I use Rexxer on, if I take my bike to the dealer and they flash the map my ECU is back to factory and Rexxer needs factory reset. HD the same?
Thanks
So could I use another map upload system and retain map access with all previous registered programing devices?
what ECU permits it please?
