Cleaning Whitewalls
  • la0055
    la0055
    Hi Guys
    I recently put a Shinko whitewall rear tyre on my Sporty.
    The whitewall was 'blue' on the new tyre (the dealer tells me that is how they are supplied) and he cleaned it off to a white mon fitting, but it is not as white as I would like ... it is a bit yellow in fact.
    Any ideas on cleaning and bringing it up to a bright white whould be appreciated.
  • brash
    brash
    Prepsol dude, stuff is magic.
    The yellow is the silcone coming out of the tyre .all tyres do it... The best is Jiff and a soapy steel wool pad.... I would do my shinko tyres every few months.
  • la0055
    la0055
    cheers guys.
  • la0055
    la0055
    Thanks mate.
  • Rocky2010
    Rocky2010
    On the girls Sporty we use a thing called Gumption Multipurpose Cleaner Cream 500g  $5.36 you can get it from Woolworths, its used for cleaning stuff in the kitchen
    Put the bike on the lift then we put a low round bucket filled with warm water under the wheel, put some Gumption on the scrubbing brush and clean away, they will come up white again, works a treat have been using this stuff for years.
  • MADOGA
    MADOGA
    No idea if its valid for bike tires but toothpaste used to be good for cleaning white stuff like that.
  • 89_tintop
    89_tintop
    I'm with rocky2010.
    Have used gumption for years on white lettering on tyres to make them shine again. Used it recently on my white walls and they came up looking great.
  • ConR
    ConR
    +1 to Jiff and a steel wool pad.
    Prepsol works very well, but you literally have to clean a small section at a time, and move to a different, clean part of the cloth. Otherwise you just end up smearing the dirt back on.
  • Hooters
    Hooters
    I've used all the other stuff and have found chux magic eraser is by far the easiest and quickest.
    Just use it with water, give It a light rub and you're good to go. It's that easy.
  • Sida
    Sida
    just used some Jif and a scotch brite pad on my WW over the weekend. Came up like brand new.
    yep
  • ScottsR8
    ScottsR8
    Solvol soap seems to do a pretty good job as well.
    http://www2.woolworthsonline.com.au/shop/ProductDetails?Stockcode=347789&name=solvol-soap-bar
