Breakout soft tail. number plate holder
  • mpg92
    mpg92
    number plate holder relocation an chop  & led number plate bolts for numberplate light.
    what do use think ?
  • mpg92
    mpg92
  • mpg92
    mpg92
  • mpg92
    mpg92
  • rodrocket
    rodrocket
    have you just cut the original bracket & drilled the mounting holes for the plate higher up in the bracket
  • mpg92
    mpg92
    looks good damo103
    rodrocket i took the inner gaurd out an drilled  4 new holes 20mm forward from the old holes . and cut the two little tabs of the gaurd
  • RockerSteve
    RockerSteve
    Hi Mpg 92,
    are they the stock rear indicators and plate cover that came with the bike?
    Rocker Steve
  • BradndAlly
    BradndAlly
    Very nice Touch Damo, been looking to do something with mine as well, just needed the idea tom start..
    Very Nice...
  • BradndAlly
    BradndAlly
    Finally done my plate mod... Bought part no # 59500108 (Inner Support Domestic) made a bracket to mount the plate on, added an LED from fleabay and Whalla......
  • BradndAlly
    BradndAlly
    Bassani..
