Online: Adam76
Chain drive conversion - minimum clearances
  • 45WL
    45WL
    Any one know what the minimum recommended chain-tyre clearances should be?
    thanks
  • Burnzi
    Burnzi
    Did one on the weekend, tyre clears the chain by 12mm. I saw one once that was getting polished by the tyre, I reckon thats a bit close! What bike/tyre combo are you doing?
  • 45WL
    45WL
    Thanks Burnzi
    Do you think 3 - 4mm sufficient??
    Anyone else?
    3-4mm is very close. I'd want more than that for peace of mind
  • Burnzi
    Burnzi
    I reckon a 6-8mm spacer front and rear would make ya happier.
    what burnzi said min 6mm tyre to chain clearance remember the tyre grows when hot , if it was a belt I would say 5 but you want a bit more with chain
    the last thing you want is for it to bite the tyre
    Use a 520 Chain, They have much less Side Flex
    What......A 520 flex's less than a 530?
    yes
    or use a non o'ring type , just keep it clean & well oiled/greased, latest built stock raked kunckle frame with a 180 rear , 520 spockets & good non o'ring chain ,  we use to run them on the old 883 roaring sporty roadracing bikes  with aluminium rear sprockets
  • 45WL
    45WL
    thanks guys for the inputs
    I'm running a firestone 500-16 and probably only have 3-4 mm lateral clearance especially since this tyre and chain will flex
    Iooks like I need to space the sprockets out - +/- 8mm should do it???
    4m.m. will pass , string line the rear wheel , keep the chain well adjusted  ,   with you sitting on the bike
  • 45WL
    45WL
    Thanks DR56
