Online: kocho, Uncle Ho
suitable rear shocks for Road king?
  • gidgi
    gidgi
    Not happy with the OEM air ride on my 2012 Roady  been looking at progressive  rear shocks but so many variations 412, 430, 444, & 940 all different  price ranges & adjustablity, so confusing! my bike has lowering blocks on atm so if I buy lowered shocks( was thinking 1: lower) I can do away with lowering blocks , I also seen on the 940 ultra touring set, that they claim the standard 13" with the look of a 12" shock, something about the secondary compensator spring, can anyone that has used these give some insight? or what you have used on your touring? many thanks in advance Rod
  • Big Steve
    Big Steve
    What is your budget?
    You generally sacrifice ride quality when you lower. I've got about 30,000km on my Legends and cannot complain at all. When I get a tourer it will also get a set.
    This is on a Dyna not on a touring bike but I'm a heavy rider doing a lot of miles.
    Dump the airshocks. I have HD pREMIUm shocks, thet are a spring shock with a remote compression adjuster. I have done nearly 40,000klm on them touring fully loaded, solo, on all types of road and surfaces. They are not perfect but a million times better than std, believe they cost me $450?
    2012 Street Glide
  • gidgi
    gidgi
    well I removed the  oem air shocks & fitted progressive  444 shocks I Have`nt tried it loaded up yet but its def stiffer maybe a little too stiff! I also took off the lowering blocks ,it has made the stearing much more responcive the big 21' on the front & dumped 2' in the rear was too much ,so it is def an improvement.
