Online: beaglebasher, Hilly
Fatboy lo burleigh bars
  • cck67
    cck67
    Just fitted 6" rise burleigh T bars 1"3/4 to my fatboy lo dealer told me I would need all new Calbles and wire extensions. Done the job myself in about 4 hours bought the bars on gumtree for $450 great deal. Don't just listen to what the dealer says most of them just rip you off, I was told the job would be to hard to do myself.Any way they are very comfortable and look great.
  • robots
    robots
    Hi,
    Yeah nice job man
    Thanks
    Robots
  • 98superglide
    98superglide
    Good stuff.
  • Crowy
    Crowy
    nice
    Looks great mate.
  • poverty rider
    poverty rider
    the bars are awesome, I like all the black.
  • cck67
    cck67
    These bars are friggin great, I can not believe what a difference they have made. Iam 6ft3 and had to lean forward to reach stock bars, would recommend to any others having issues with 2011 fatboy lo bars. Only thing is I may have to get longer front brake line as it does not quite look right, does the job but hangs down from bars to much. Took a long run the other weekend no more sore back.
  • Hound_Dog
    Hound_Dog
    Good job mate and I like your style. It will be a cold day in hell when I ever give a dealer work to do on a bike I own.
  • groover
    groover
    Now that you have done it once, you won't be able to stop fitting different bars for variety.
  • groover
    groover
    Oh yeah, look great also.
    Just love a good set of T-bars.
  • simmac18
    simmac18
    They look great, they should suit you I'm not that Tall and I had a set on my Fatboy, they still weren't right so I put a set of westerns from Burleigh on which suit me, but simple to do, it's satisfying to do that sort of thing and save a few bucks. Nice ride
  • bobby bob
    bobby bob
    i like it, I like it a lot.
  • oneball
    oneball
    Hi all...cck67,Ive got the Harley version of your bars.Watch out for the clutch cable hitting/scratching the rear of your front guard.Although it may look like you have a ton of room,When the front shocks compress the cable will touch.I have the same bike and fitted my bars myself easily.
