Online: Humbug, Hilly, speedzter
Ultimate petrol affecting tank seals.
  • graeme_t
    graeme_t
    I have recently had an issue with the rubber seal under the dash of my 2013 Softail Standard leaking and stuffing the paint on the left side of the tank. I was told that it was a combination of the plate being over tightened during manufacturing and the recent hot weather. Then on Saturday I went for a ride on my 1979 Shovelhead Lowrider and after filling the tanks I had petrol suddenly leak out of the cap. On checking under the cap I found that the rubber seal under cap was stretched and no longer sealing. I had a spare cap at home so I changed the rubbers over, with the new rubber a nice tight fit. Today when I took the cap off I found that the new rubber was now loose. On checking the old rubber I found that it had shrunk back to its normal size. I have recently changed from BP Premium 95 to BP Ultimate 98 petrol and was wondering if anyone else has had any issues with their tanks leaking.
  • 06 Softail
    06 Softail
    Thiis is the first I've heard of the problem.  Sorry that I can't provide an answer for it.
  • mickle
    mickle
    Used the BP 98 for a few years now without issues.
  • Wimbo
    Wimbo
    I've had no problems and generally use Ultimate when I can.
    So are you suggesting that the different spec fuel may have damaged the seal of your petrol cap/s?!
    E85 Ethanol kills Rubber Seals and Standard Fuel Lines,,, I would say the Service Station your getting you Fuel from is mixing in E85
  • Big Steve
    Big Steve
    Another happy BP Ultimate user here. 50,000km mainly from 4 different BP servos
  • graeme_t
    graeme_t
    Thanks everyone for replying. I have used the BP 95 for years without a problem and won't have thought changing to the Ultimate 98 would have caused any trouble but like walka suggested, I am thinking that the Ultimate 98 may be an ethanol mix, either by mistake or as a cost saving measure.
    No issue, with BP 98, but owned a shovel from new, think stock fuel cap used cork, but don't give me a hard time if i'm wrong.  & think the rubber seals u got are aftermarket i had trouble with them too long b4 bp 98. also my shovel still runing strong , mate owns it & still rides interstate when he can .
