Online: John.R, Dragon Man
do i need adjustable pushrods with se-4 cam
  • jonboy32nz
    jonboy32nz
    installing a se-4 cam can i get away with using standad pushrods, the cam has .505 lift
  • jonboy32nz
    jonboy32nz
    cool thanks for the reply i knew they were a bolt in but werent sure if a "true bolt in" ..heads are off getting ported so no need to cut em ...maybe its me but id never cut a set of perfectly good pushrods anyway ....it aint that hard to undo rocker covers :)
  • robots
    robots
    Hi,
    You have some maths to do to work it out i would suggest
    Thanks
    Robots
  • Yob
    Yob
    Hi
    You say the heads are off for porting ?
    If you deck the heads & touch the valves & seats it might pay to put adjustable pushrods with tubes.
    it will save you having to do it after you bolt it back together & find the lifter preload out.
