Cam upgrade for my TC 96
  • hamerz84
    hamerz84
    G'day guys I'm new to the site.
    I know this might have been asked or spoken about previously but I cant find it anywhere in the history Search bar.
    I've got a 2010 dyna wide glide with a stage 1 heavy breather and v&h 2into2
    I had a fair improvement with those mods but im after abit more low to midrange pull say between 2000rpm to 4500rpm.
    every mechanic or harley dealership I speak to gives me a different opionion,
    ive had people tell me se 204's all the way up to the  se259e's
    Has anyone had any work like this done or can anyone offer any advice as to what I should get done ?
    I'm thinking screaming eagle 254e bit I'm not to familiar with compression and all the other stuff I would have to do get it running write.
    i dont want a cam upgrade just for the stuff of it, I actually want it to run at its prime. Happy to get it dyno tuned aswell once I choose the right can.
    Many thanks in advance.
    Hamada.
  • robots
    robots
    Hi,
    nice ride apart from the rear fender he he ha he ha hehehehe
    i just picked up some se254's to put in a 96ci wide glide, give them a run, i know geoff3admin i think he calls himself has them in switchback and the review is pretty good, darke peak has some se204 in his switchback and achieved good result
    thanks
    robots
  • hamerz84
    hamerz84
    Thanks robots fender was on it wen in bought it I'm not a big fan either lol
    myane down the track a 240 arse end but no coin at the moment.
    Are the 204's more lower range ? When will I feel the difference come through ?
  • hamerz84
    hamerz84
    Hilly would compression be an issue with the 204's ?
  • hamerz84
    hamerz84
    Ok thanks for help.
    One dealer mechanic suggested 259e with high comp heads and modified push rods. What would that give me.
    Kinda makes me think if I'm gonna spend that sort of cabbage I might aswell just go with a stage 4 or there abouts.
  • fat55
    fat55
    I went with the stage 4 , got 109 & 110 very please with the result .
    wait for winter then shop around with the dealers and they will do you a good deal on the kit
  • Big Steve
    Big Steve
    I've got Andrews 37H cams to go in my 2010 TC 96 at the next service. (already has a stage 1)
    I wanted a bit more low and mid range but not necessarily a fire breather as I ride every day in all conditions.
  • 45WL
    45WL
    Just received my set of Andrews 57H for my 96" WG (Stage 1) - I'll install and leave a product review in the next couple of weeks -  Its really confusing out there with SOOO many options/opinions ;-) Just keep reading and keep on learning/ experimenting ;-)
  • robots
    robots
    Hi,
    Sparra i think it runs at about $1500 at dealer for the cams, parts assistant at HH was telling me to keep an eye out for winter deals coming up
    What you reckon about changing the cam bearing and lifters? Oviously lifters you can check as per manual specs but is the cam bearing another "oh know" its harley bearing then no good whip it out for a timken
    Wives tale like change wheel bearings when you change tyres he he ha ha he he ha ha
    Thanks
    Robots
  • robots
    robots
    Hi,
    hope this comes out, apparently have to check bore and lifter diameter and play, probably be in most manuals
    thanks
    robots
  • robots
    robots
    Hi,
    Yes just get some new ones and plonk them in easy as, the cam bearing an interesting one as manual doesnt mention wear limits, inspection etc just pure removal and install
    33000kms on stock cams, wheel bearings fine , neck bearings fine, interesting
    Thanks
    Robots
  • Rob_hendo
    Rob_hendo
  • 45WL
    45WL
    have all the parts, just waiting on the cam bearing removal/ installation tool.... The sender sent it to the wrong post code, and its "lost" in the system since the 4th March..... hopefully it will turn up soon and I'll post my review and results. I intend having it dynoed so then I post the results
  • robots
    robots
    Hi,
    Good stuff, you using stock push rods or going with adjustable? If you got tool from Heartland on ebay i received some tools of them just recently and they are reasonable stuff
    Thanks
    Robots
  • 45WL
    45WL
    Robots
    I'll be using S&S quickies - was told they top quality and minimise the f!@# around factor lol
    Ordered the Gary Beatty tool - it got good reviews on the US sites. $120 US including postage
  • robots
    robots
    Hi,
    Thanks, how you get in contact with gary beatty, i am looking at the Heartland setup which is $200 landed which includes the bearings
    Thanks
    Robots
  • robots
    robots
    hi,
    good stuff, anyone put the comp cam 850-1 in?
    thanks
    robots
    Robots, the comp cam lifters work well.
    I've used both the 850 and the 875.
  • robots
    robots
    hi,
    thanks for the info, you know of any aussie suppliers or all online via ebay
    thanks
    robots
    Send a message to Dynoharley, he might have some.
    Otherwise M&M.
    I know where you can get Gatermans here as well.
