Online: John.R, Dragon Man
883 Sporster Timing (2013) ??
  • Fritzables
    Fritzables
    Hi All,
    I have a 2013 883 Iron fitted up with Pipes & Air Cleaner. TTS MasterTune looks after the AFR Table and over time have sorted my VE Tables out.
    It's now time to look at ignition timing.
    I run nothing less than 98 Octane fuel, always have done from day one till present day - this will not vary.
    Looking at the Timing Tables it appears the timing is pretty conservative and have made a general advancement across the board of 3 degrees with no pinging.
    From your experience, how far can I safley before I stop and make the finite adjustments??
    Fritzables.
  • Fritzables
    Fritzables
    G'Day Hilly,
    Yea, I guess your right to a point, but I am one of those types who can't leave things alone. I can remember when I was a kid and bought my foist bike (BSA M20) for $10 at High School, I had to bomb the motor on that
    - SU Carby, Grinding CAMs on a Bench Grinder..... pretty scary stuff when I look back.
    I am a Motor Mechanic by trade and have built a number of performance engines but they have always been water cooled Jap engines - both 2 and 4 Stroke. Used to race GP bikes that I built myself.
    This is my first recent Air Cooled non-Jap bike so I am a little wary, thus the question.
    I have already gone 3 Degrees all round with no pinging detected - just need to know how far I can safely go before looking more closely at things.
    Pete
  • terroristone
    terroristone
    If you get back what you put in then leave it, if it make barley any difference then take it back out.
    T1
  • Fritzables
    Fritzables
    Morning Hilly,
    Thanks for the reply.
    Yea, I have done countless runs and long rides to gather data for the VEs, so I am reasonably happy with that side of the fence.
    Correct, the base Calibration is the SXD171-02-B2.MT7
    Out of the box it used a CLB of 600 so I took this to 620 prior to DataTuning - but thinking back at it, I have no idea why I chose that number. This is one of the areas where I fall down and doing my best to understand all this. Back in the old days I had jets to change - not the case these days.
    The intent would be to stay with Closed in the areas cells as per the original calibration, but as I become more confident that I am choosing the right numbers in my tables, then I will open up sections of the AFR Table at a time till I am running full open (except in the High RPM WOT cells where I will leave that closed).
    Thoughts ???
    Pete
  • Fritzables
    Fritzables
    G'Day Hilly,
    Yea mate, knew that all RED cells are Closed Loop.
    I think I will start again.
    Would you leave The Desired AFR at 14.64 in the CLB Voltage Calculator? As we I use 98 Premium fuel I was going to use a Stoch of 14.7
    Pete
  • Fritzables
    Fritzables
    Hey Hilly,
    Mate, this stuff is awesome. I could read info like this for days. Thanks very much for the advice.
    Very much appreciated.
    Pete
