HD braided fuel tank crossover line
  • sime69
    sime69
    Who has one and do they leak? Can I put it on myself?
    I've been reading various reports, as per usual some think its great and some say its BS.
    ..just looking for something to get rid of the crappy looking stock rubber pipe and those sharp little b*st*rd fasteners that take skin off when polishing cylinder heads!!
      sime
    i have one fitted... it is not really designed for the nipples on the tank... only advice is to make sure the tank is empty..
  • blueystar
    blueystar
    WILL SOON FIND OUT HAVE JUST ORDERED ONE ON E-BAY
  • imoo6170
    imoo6170
    I purchased a HD one and found it easy to fit. Had to full the tank off a couple of times and found that after about the 4th or 5th removal I needed to replace the rubber washers so that I got a leak proof seal. Other than that couldn't complain.
