Online: Ultramick
Hard Starting
  • hellboundpig
    hellboundpig
    G Day I have a  07 Softail  103 cci with 211 cams 0.30 cometic jaskets heavy breather standard throttle body big shot exhaust allready upgraded to a heavier starter motor and battery but I am still have problems with cold and hot starts I am running TTS mastertune Do i need comression release or is my TTS map at fault bike runs flawlesy but just loads up on first cold crank and Hot crank any ideas would be appreciated cheers Stevo.
  • KiwiRob
    KiwiRob
    Sounds like you will need compression releases. Assuming you are running flat top pistons, 86cc heads with 0.030" HG your CR is a little over 10.1:1 & just short of 190 cranking pressure. Even if your heavy duty could turn it over easily without releases, the starting ring gear would chew itself fairly quickly, so comp releases would be a good idea.- Rob
  • hellboundpig
    hellboundpig
    Cheers Kiwi Rob Looks like compression Releases my heads are stock but have flat top pistons as part of 103 kit It seemed to start a lot easier when it had the Thundermax on Then when i went to tts Its seemed to cause hard starting problems .the motors done 30000 kays since the kit was done cheers Steve .
  • Yob
    Yob
    I have the same combo as you 10.4:1 comp but with crane 320 cams.
    cold it will just turn over with a new battery but baulks on the starter once in a while when hot, have fitted manual compression releases & alls good.
    cheers Yob
  • hellboundpig
    hellboundpig
    cheers for that looks i will have to go down the same path Heads off again bugger .
  • EBT
    EBT
    Hi, The SE 211 cams are a starter motor muncher. The cranking compression seems to be higher than allot of other grinds.. You need to have some sort of compression release fitted. I use the S&S easy start cams so that no other mods are required. Sometimes a shop can change to the easy start cams cheaper than removing heads and fitting either manual or electric decomps.
    Cheers Brian.
  • graeme
    graeme
    95'hi comp pistons,se heads with manual comp release,mikuni,211 cams still on same battery when build was done 41/2 years ago battery still ok so comp releases do help
  • Mr_Bean
    Mr_Bean
    Have the same probelm with my bike.
    Bites back on the starter. coughs out through the throttle body cold or hot but mainly when it is warm to hot..
    Was told to look at the primary compensator and change it out with a SE version.
    Was told to look for metal on the magnet in the primary as well
    Bike has done 37,000 km
    Have the parts on order and will be changing them out through the week
    Will let you know if it fixes the problem
  • Gonads
    Gonads
    Running 205 cranking pressure with a baby small duration cam. No decamps but run travel limiters and yet to have a problem with hot or cold starts. Might be an option as cheaper and quite easy to do.
  • EBT
    EBT
    Hi Dynoharley,
    Your are clearly one of the lucky ones. As apposed to the countless customers that have paid me their hard earned to repair their starter motors and replace their ring gears after the teeth have been broken off. Even the engines with decomp buttens are a problem because the owners admit they dont push them all the time.
    That is why we only use the S&S easy start cams. Amazing hassle free starting.
    Cheers Brian.
  • hellboundpig
    hellboundpig
    Thanks for your input I will bee looking into manual compression releases cheers .p.s anyone in w.a have there Heads machined to take manual Releases and how mutch cheers .
  • Gonads
    Gonads
    Posted By hellboundpig on 28 Mar 2014 5:04 PM
     Harris Engines in Ozzy Park and Galloways (I think thats their name) in Pinjarra do them. Sorry, dont know how much.
  • Steve Cole
    Steve Cole
    There are adjustments that can be made to aid in starting but the ECM can only do so much. It must issue spark and fuel in order to get the engine to run and keep running. If the starter cannot spin it over in all conditions there is nothing any ECM can do about it. If you would like some help checking your calibration send me a copy of what you have in it and I can take a look at it for you.
  • hellboundpig
    hellboundpig
    Cheers for the replys Steve Cole i cant seem to find any maps after installing my tts mastertune to my pc even after installing updates ,
  • Steve Cole
    Steve Cole
    You calibrations are stored on your PC at "My Documents\TTS\HD\MasterTune-HD\Big Twin Models" Make sure that you installed everthing and ran the TTS Software updater and that it shows everything is installed and up to date.
  • hellboundpig
    hellboundpig
    Installed everything with updater still know files Steve Cole .
  • Steve Cole
    Steve Cole
    Do a search on your PC for "*.MT8" using the Window search function. This will locate all files with the .MT8 file extension on your PC.
  • hellboundpig
    hellboundpig
    Still nothing installed disc again and all the updates still no mt8 files my disc is 5 years old no mt8 on my pc click on big  twin it ays no files istalled this before no problems got me stuffed lol.
  • hellboundpig
    hellboundpig
    Cheers Hilly will check it out .
  • hellboundpig
    hellboundpig
    All good didnt upload historic files all there now cheers .next is to get compression releases done ,
