S & S Inner Bearing Chamfered Race
  • robots
    robots
    Hi,
    anybody instal the S & S inner bearing chamfered race? They reckon it wont walk on mainshaft like harley one but at about $80aus landed not cheap ( can stick with harley bearing and seal in the inner primary)
    i got 32000kms out of harley inner bearing race and wondering if just as easy to press another OEM inner bearing race back onto mainshaft
    otherwise there baker high torque bearing kit or all balls bearing kit
    thanks
    robots
  • Cv ohhh
    Cv ohhh
    I used the all balls one.Got about 15000 k's on that now n no probs.
  • robots
    robots
    Hi,
    Thanks cv ohh, i look into that one as well
    As doing myself i probably have to get tool to press bearings in and out i guess if go with these set ups
    Thanks
    Robots
  • Cv ohhh
    Cv ohhh
    To get the old one off the shaft,cut it carefully with a dremel.
    Don't score the shaft.Knock it off with a cold chisel.
    I used the heartland tool to install new one.
    With the bearing,You'll need a press,Take ya time n set it up carefully n square.
    Support the cover properly so it doesn't break.
    I would definately look at the Baker one piece bearing.
    Much easier later on if you ever need to replace output seals etc.
  • robots
    robots
    Hi,
    Okay so race is crap design, whats a bearing puller/installer gonna set me back to get inner primary bearing out and new baker high torque bearing in
    Any links to one be great
    Thanks
    Robots
    You can do it with a press, or use the large socket and all thread method.
  • robots
    robots
    hi,
    thanks fella's, now i no expert but finding out the 08 models up have shaft which stops race going back towards nut and baker dont have set up for 08+up bikes
    info from other forums reckon put some loctite 640? sleeve retainer on harley race,
    great feedback, good experience working on bike as may do the 30T pulley during winter
    thanks
    robots
