Online: WideglidingNZ
High idle, idle hangs and slow to return to idle
  • sssmour
    sssmour
    I know this has been discussed before but has anyone actually fixed this problem.
    Mine is a XL1200C 2010 model.
  • brash
    brash
    checked the basics like throttle return cable adjustment?
    Check the throttle cable leading into the throttle body, it can come out of it's housing and have some slop.
  • TheBigFella
    TheBigFella
    sounds like it could have a small air leak dude, check your gaskets and vac lines
  • terroristone
    terroristone
    Also check the IAC. Common problem .
    T1
  • 308bever
    308bever
    what`s IAC sorry?
  • 308bever
    308bever
    thanks (((-;
  • sssmour
    sssmour
    Thinking it is the IAC. When you stop it drops back to correct idle. If there is an air leak it would stay high all the time and wouldn't run as high as 2000rpm. I have noticed when the idle plays up it also is very jerky at a constant 80KPH say. I believe the reason is the IAC is staying open and leaning out the mixture too much.
    I will buy a new IAC this week and try. Will keep you all posted.
  • sssmour
    sssmour
    Fitted the new IAC today. First thing I noticed was the parked position of the stepper motor valve. New one was in and the old one was out. Second was when started cold the idle speed was as I adjusted in the ECU, 1400rpm. Can't remember the last time it did that. Had always run below 1000rpm and came up as the engine warmed up. As the engine warmed up the idle came back to the preset value of 1000rpm. Took the bike for a good run and each time I stopped the engine came back to idle as expected. Appears problem solved by replacing the IAC. Case closed.
  • terroristone
    terroristone
    Good to see its fixed! Thanks for reporting back.
    Regards Andrew - T1
  • Mr Chriso
    Mr Chriso
    hi all,
    it is amazing as I was riding home from work on Thursday when I noticed that my 09 1200 sporty was doing exactly as you have described. High idle and slow to return to idle and jerky at around 80 k,s. I thought that it was needing a service, which I will do anyway, but now I know the problem. Thanks for that. I will let you all know what comes of it
    regards
    Mr Chriso
  • burtman
    burtman
    g'day mate, ive not read all the replys ,but I had the same problem. tried lots of things had the tuning map adjusted .its been right since 3-4 yrs, goodonya burt.
  • Mr Chriso
    Mr Chriso
    Hi all,
    Had bike serviced, 8,000k, and asked them to check the IAC and they said that was ok. Rode the bike through the city and everything was ok till either the bike really warmed up or because I was riding at a constant speed that when I pulled the clutch in the rev,s stayed high until the bike came to a complete stop. Could the IAC only play up when bike ridden at a constant speed or when the engine gets quite warm?
    Regards
    Mr Chriso.
  • Fritzables
    Fritzables
    Hmmmm, I am seeing this as well. Have been tearing my hair out thinking I had stuffed up one of the TTS Calibration Tables, wondering why my changes were not affective - this post has answered and I will approach the Dealer to have it replaced as the bike has only got 4,000Km on it.
    Bit worried they may knock it back due to the TTS MasterTune.
