SHOTGUN'D (suspension)
  • dezzas
    dezzas
    It's done.... couldn't wait till April so ran the Nightrain down to HD's this morning to get the Shotgun Shocks fitted. Despite the 40min trip taken nearly 2hr's with your Qld traffic and I showing up late.... the team were on to it.
    A couple of hours later and while the plastic card was still warm we found some bling on the shop walls that also got the fitting treatment straight up.
    First thoughts of the Shotgun Shock....... nice..... very nice.laugh  Need to get outa town to give them a decent thumping.
    Thankyou Simon, Kevin, Shane and ur team....luv ur work....  yes
  • terroristone
    terroristone
    you'll love them, they are the only air shock that i recommend. Spend the time and read/work out the correct way to use them and you'll really find out how good they are. If you have trouble give them a call in the US as they are always very helpful.
    T1
