Right side Sportster 2013 883 cover near engine
  • mrjk
    mrjk
    So I need a little help to understand what the right side engine cover where the timer cover is called and what is behind it.
    I can hear something rattling in there and can feel something that feels like a rock when I put my hand inside it from the bottom. I'm thinking of opening it up, but I cant find any information about what is actually behind it, what it is called and also anything I should be concerned about.
    I've attached a picture to make it clear what I'm talking about
  • Fritzables
    Fritzables
    mrjk,
    I believe it the Valve Timing gears.
  • terroristone
    terroristone
    cams
    how many klms has the bike have on her, i would not pull that cover off without buying a factory manual 1st , because you have to come in thru the top rocker boxes & pushrods 1st
    +1 ...Buy a friggin manual or you will end up with a very expensive paperweight.
  • mrjk
    mrjk
    It's been 3000 km. yeah I thought it would be pretty bad to have that opened up. It's technically still under warranty until next year. Probably worth while taking it into the Harley store?
  • careyman
    careyman
    only done 300km and u have a rattle in part of the engine and u wonder if you should take it in???? until the warranty goes out I would take it to them for this FOR SURE... plus, if you go tinkering on the bike yourself your warranty might be void then you really are up shit creek...
  • Colstah
    Colstah
    I'm puzzled about how you get your hand in there. As far as I know, it's sealed with a gasket.
    Do you mean the cover to the rear of it, cos that's a cover for the sprocket, and I guess a rock or something could get in there.....
