Online: GGUser744, speedzter
what should a service cost
  • cobar500
    cobar500
    Been told my new super glide custom for its first service will cost around $ 400, at stevos in dandy , is this about right as my new car cost half that amount to service ,
  • blueystar
    blueystar
    that's what HD stands for hundred of dollars
    Should , and does , are a bit different . Afraid $400- is around the mark , till it,s out of warranty .
  • terroristone
    terroristone
    I do full services for $350, thats all 3 oils, brake fluid front and back. Neck bearing adjustment, belt adjustment, clutch adjustment, safety check, nut/bolt check etc.
    Regards Andrew - T1
  • ozymax
    ozymax
    the first service SHOULD be materials cost only but it usually isn't unless you include that in the purchase deal
    My local indep shop charges about $270 for a basic service which includes oils general check over and today they adjusted the belt and clutch.
  • Wimbo
    Wimbo
    Get Terristone to do it.
    He's also a Website Sponsor.
  • Pastrypete
    Pastrypete
    Just got my 2011 Superglide Custom done at Sys today and got great friendly service...$400 for a 16,000k service
  • reaver_05
    reaver_05
    Ditch the dealer, they don't do half the things they are charging you for, and find a good local motor cycle mechanic. If you have some basic mechanic skills you can carry out most services yourself.
    +1 there....At 16,000km you should really be doing your own service. Or send it down to me and I'll do it for $300 and smile a lot!
  • Nomada
    Nomada
    You said "your new" is that new as in still under warranty or just new to you.
    If new to you and out of warranty, a service should cost ....
    Some time on youTube looking at how to adjust your clutch, belt and chain (surprisingly easy)
    Some cleaner and oil for your air cleaner (if its re-usable) new filter if not.
    New oil filter (funny enough HD seems the cheapest $12ish)
    Oil (some use Mobil 1 V twin in all holes. (but do your own homework on that one) and
    2 spark plugs.
    Some might do brake fluid but how often do you do your brakes on your car??
    At least here in Adelaide, Peter Stevens don't do minor and major servicing, they only do the big one even if your service book says different.
    Therefore my next service is a DIY.
    What could possibly to go wrong..........................
  • Rocky2010
    Rocky2010
    Do it yourself, bugger the warranty
  • Spook
    Spook
    My Road King is getting on a bit but I have never paid anyone to service it. I use Mobil 1 V twin in all the holes and it's not hard to tinker with the rest in between enjoying the rides. It does not however have all the fucking electronics with which the late models are plagued, just fuel injection. I guess if that gives me any grief I have a mate a kilometre away who is a bike mechanic (retired) who is only too happy to help.
