Online: baldy1450
SE Performance Clutch Kit 37980-10
  • markwoumla
    markwoumla
    Hi All,  Anyone replaced the stock clutch plates, part no 37932-98,    ( friction and steel ), with the SE performance clutch kit, part no 37980-10   ??  Bike is 2009 flht Electra Glide.
    In the stock clutch there is a 1. Narrow friction plate 2. Damper Spring   3. Damper Spring seat  4. 9x friction plated  5.  8x steel plates .
    In the SE performance clutch kit there is only 9x friction plates and 8x steel plates to install !!    The way I see it,  is that the Narrow friction plate ,  Damper Spring and the Damper Spring seat are deleted , and you install friction and steel plates only . (  Of course you re use the Pressure plate  ,  Diaphragm spring and Diaphragm spring retainer .)
    Im just a little confused and dont wont to mess things up while I have the primary opened .
    I have attached diagram of Stock Clutch from manual .      Thanks Mark
