Michelin Rear
    Anyone running one of these new Michelin rears that they recon you can get big klms out of
  • rider
    rider
    Commander II ? yep, fitted one about 8K ago,looks like he's still got at least that , maybe more left in it.
    Had no probs with handling, can't say how they are in the wet cause haven't been there.
    Can't fault it yet.
    180 on the back of an FLHTCU SE7
    Ta so about the same as the Dunlops. I got 18k out of the originals mostly fully loaded. Do youremember how much you paid for yours by chance? Did you go the same on the front?
  • rider
    rider
    Will be better than the dunlop, only got 13 K out of the dunny, it also seems to be wearing "rounder" than the dunny, not as flat.
    If I remember correctly I paid around $320.
    Still got a ways to go on the front dunny at 22K, but when the time comes I'll replace it with a Commander II.
    Also fitted a 80/90 x 21" Commander II to the front of the Wide Glide, looks better, feels better, wears better, very little balance required, more than happy with it.
