Online: Hilly, Ultramick
Removing quick connect fuel valve
  • 06 Softail
    06 Softail
    Hi has anyone had to replace this part before on their efi harley and fitted it themselves? Mine has developed a leak.  I'm going to attempt it myself, & need some advice.
    Can someone post a link to an online manual to do this, cheers for your help.
  • AJ56
    AJ56
    Remove the fuse to the fuel pump, Start the bike and let it run till it runs out of fuel. Locate the Quick Connect Fuel valve, Pull down on the chrome upper sleeve and remove the lower valve. From there remove your tank and remove the fuel line from the Throttle body. It just slides on.
    Your manual is here https://www.dropbox.com/s/fl757h7qu4igemz/SOFTAIL-2006-Service-Manual.pdf
  • cm364352
    cm364352
    I believe you can replace the "O" rings in the quick connect fitting if that's where the leak is.
    WAZ...
  • 06 Softail
    06 Softail
    Thanks AJ. WAZ, yeah I've read about others who have replaced the o ring, on other forums. I've bought the replacement connector, but will return it if I can have a go replacing that o ring. Does anyone have a seperate part number for it?
  • cm364352
    cm364352
    You can use 11105 "same as oil drain plug" for the thinner one,and
    11187A for the thicker one.There supposed to work ok.I've been warned
    that they are a real pain to get out when left on the bike.
    WAZ...
  • 06 Softail
    06 Softail
    Hi guys, I found this handy video on how to replace the O-rings, which is what needs to be done on mine.
    Unfortunately Harley Heaven don't stock the special tool, or O-rings.
