Online: John.R
O2 Sensors, do I need em?
  • Bandageboy
    Bandageboy
    Just installed a new exhaust (RSD Slant 2 into 1) and one of the O2 sensors does not quite reach, so for not I have left the hole plugged (it came with bungs) and it looks MUCH nicer without it in. My question as in the subject is, do I need them in at all? I have had a look around and from the info knocking about it doers not look like it, I have an RSD Turbine aircleaner on thebike and have tuned it with a SEPST, my hope is that I can just remap for the new pipes and forget about the sensors.
    Thought I would ask the collective knowledgebase if this is going to be an issue or just a bad idea..
    Thanks for teh help!
  • Cv ohhh
    Cv ohhh
    It should be ok.Just means it won't compensate for different altitudes etc etc.
    So just make sure your tune is pretty good
  • Bandageboy
    Bandageboy
    Cool! have taken the sec on done off, looks much better, will keep an eye on the tune! Will also try to do a new smart tune this week for the new 2 into 1 pipes.
  • Ando
    Ando
    hope ya tune is in open loop
  • KiwiRob
    KiwiRob
    Ando is right, if you remove/disable the 02 sensors, you could damage somthing, unless the ECM is in open loop. Your ECM is most likely in closed loop. - Rob
  • Bandageboy
    Bandageboy
    Thanks a Rob and Ando, I have remapped he ECM so that all values are below 14.6 which should put it into an open loop, will take her for a ride today and see how she behaves!
