Online: Hilly, Ultramick
Digital Speedo prob?
  • Bushido
    Bushido
    Hi All, just installed new speedo on my iron have done about 80k's so far! I noticed that my left indicator only works occaisionally?? Has anyone else experienced this or similar problem? Bushido. thanks
  • Bushido
    Bushido
    Ok think I have found problem! just coincidence it started playing up after I put speedo in. Would not have thought speedo was problem anyway, seems to be switch not contacting properly jiggling the switch can make it work. So will look at contacts in switch.
