Online: speedzter
maybe a dumb question
  • brush
    brush
    now i am not very mechanical minded, but if ya had say two identical  103 donks with  same cams, air filter , exhaust  etc,  one was fuel injected  the other with a big carby,  which one would make the best horespower and torque      cheers    BRUSH
    The one with the turbo!
  • Cv ohhh
    Cv ohhh
    Depends how they are tuned.
    There's too many variables.
    The advantages with EFI over Carb, are Cold starts, EFI doesn't need a choke, EFI will give you a more efficient fuel mixture, mixture will even be adjusted for the barometric pressure and altitude.
    Logically if EFI is more Efficient it should give you higher figures with Horsepower and Torque.......
  • rider
    rider
    Try riding a carby model over the Rockies along side an injected model,,,, you may wish you didn't have a carby model.
  • Cv ohhh
    Cv ohhh
    Cv carb will compensate for altitude.
