CLEANING HARD TO GET PLACES
  • shingles
    shingles
    this may have been written but anyway for what its worth ,im c;leaning me teeth with new electric tooth brush that dentist gave me coz i wasnt pushin into gums hard enough when cleanin them ,i fukin hate doin it cunt of a thing fukin teeth ,well now ive gone why da fuk didnt i get 1 yrs ago ,so as im lookin at this little spinnn head goin around something clicked fuk dis im out side put on some mgwyers metal polish an lets see if my idea good or not an fuk me fatal this electric toothbrush is turning that dull alloy ocizdation look into chrome with this cream i only did a sample spot but it worked this electric brush hed spins around not jus oscillatin or vibratin it was made 2 stop plaque buidup push into gum an flik shit out but now can polish shit an i tell ya wat the fukin thing wont giv in with battery flattenin u will wear out first an wen ya turn on stays on for 2 mins so u dont hav 2 hold button i bought another 1 from good guys 47dollars delivered an ya get three heads as well an charger ive left off charger 4 days no prob goes like a trooper fukin stong motor in thing ,u kood cut brisstle off glue buffin foam on an be even better ive even used it for cleanig coins o the list is endless ,and yes there probably tools out there that do this i dunno but 4 $47 i dont really care an ya can still clean ya teeh afterwards an cunt will work underwater SHINGLES
  • 45WL
    45WL
    good plan Shingles - Ive used normal toothbrushes before but never thought of using an electric toothbrush - brilliant!
  • shingles
    shingles
    well i fogot 2 say brand of this brush coz theres lots out there but is braun oral b i bought online the second one fukin thing indestructable strong motor grab bristles and 2 stop wen going nearly impossible and ya get charger 3 additioal heads i rekon ya could even make some extension thing and use shaft stickin out from motor part but overalll this thing has alota uses besides teet cleaniing wen ya think about and fukin waterproof SHINGLES
  • Bashful
    Bashful
    Hi Shingles, Sorry me ol mate, I read your topic and I have to be sarcastic, but no offense mate, I am just joking, I have actually dipped a spray gun cleaning toothbrush in petrol recently and scrubbed various areas of the bike to get rid of the white metal polish that got on the black powder coated components.
    How do you clean hard to get to places? Leave em fucking dirty. lol
  • shingles
    shingles
    geezez was hoping hook  few more in yet ah but ah only wrote 4 the ones that reallly do get into this mines got streamers an chrome whoda wattas and watever ,fuk im luky 2 clean myself let alone bike can hardly stand up let alone polish anything ,need dem cheap workers do shit like that and always forgettin 2 clean my teeth ,but i bet some have taken advice and will buy SHINGLES
  • tommygun
    tommygun
    for a wrinkle black finished motor buy a can of engine highlighter
    it hides any hard to clean bits and blackens the engine casings
    I normally take the wash and ride approach, but today I had some free time so I sat on my arse for about an hour getting the front spokes clean and they still aren't near perfect. I was going to do the back, but I got pissed off with it and went out instead. After reading this I might go buy one of those cheap electric toothbrushes and get all the spots I couldn't reach. Nice tip.
  • Spook
    Spook
    Shingles spends so much time cleaning his ride that he doesn't even have time to properly punctuate his posts FFS!
  • shingles
    shingles
    geez im guilty of my own neglect cant remember en last washed cycle an as far as polishing well can barely stand da pain of actually ridin dese dayz, would love 2 make shiny but alas body wont allow such posisitions 2 engage as sum say 2 much time well ,ya rite I av all da time in da world just not the ability ,wile on this cleaning thing I will quote that Harley sell a product q 100 washing solution now I av used this and will not damage alloys or other components u spray on with spray bottle all over and hose off this q100 CLEANSER IS THE BEST washing agent bar say truk wash ,hose off imedaitely hard pressure and no streaking ,I push bike bak in shade is best no rub with rag just spray wait a little then heavy hose ,they call it the 15min wash or sumthin ,but is hexy 100 buks 5ltr but I mused and would recommend as number 1 product in ease of cleaning bike just the cost ,but does do lots of washes and guaranteed by HD that product will not damage components or finish now that's a big call ,ive used over da yrs and never had any probs SHINGLES
  • GT 1200
    GT 1200
    The toothbrush worked great, but now can't get the taste of Autosol out off my mouth! crying
  • shingles
    shingles
    ah 4 wat its worth cleaning our items is a chore ,I must admit im full of yep im gunna clean dis an dat ,but alas mostly never happens o I got cleaning solution name wrong it,s called SOL 100 bloody exspensive but doe,s clean bike well without much input then again truckwash works well to ,and best metal polish ive used and easy rub on and off with little input physically is meguiars all metal polish works a treat easier than autosol and results instantly with less effort ,AN WEN WASH car or bike I blow dry with leaves blower beats wiping dry with chamois blows water off no wiping works a treat yard blower ,makes drying so much easier SHINGLES
