Risers on a Road King
  • Chancellor
    Chancellor
    Gotta change the bars out on the roady for the longer rides.
    I've heard of some guys putting on 4" pullback risers to bring the stock bars closer and up.
    Has anyone done this?. Do all the stock cables stay? Whats involved?
  • Deadwood
    Deadwood
    Had this set-up on my Road King when I bought it, couldn't answer your questions about cable lengths but looking at the cables I reckon they were stock (inc. brake line) except for possibly the clutch cable.
    I still have the risers, bar clamp, clutch cable and shroud etc. Going cheap if you wanna save some bucks on new ones. I changed out to 16" apes.
  • Chancellor
    Chancellor
    Cheers Deadwood. I'll eventually go the 14" Wild Ones, but figured the risers and stock bars might do for now if I can get away with the stock cables.
    What year model randy ya got, where you at and what are you after for them?
  • Chancellor
    Chancellor
  • Chancellor
    Chancellor
  • Chancellor
    Chancellor
  • Chancellor
    Chancellor
    Fuck that is some sort of a stutter you have there
  • Deadwood
    Deadwood
    Reckon someone was a bit randy.
    I have an 09 FLHRC, same as you.
  • Deadwood
    Deadwood
    And I'm in Melb and reckon $75 would cover the lot + postage if required.
    I went the 16" Wild1's and would go 18's if the lawman wasn't so much trouble
  • Chancellor
    Chancellor
    The stutters bit of a bitch, happens when your service is crap.
    Deadwood, I'm interested.
    If you want to PM me, we can discuss further.
