What do you call these? (pic)
  • BeeFa
    BeeFa
    Yeah a castle nut will get you what you want.. or castellated nut or slotted nut will all see you right
  • Burnzi
    Burnzi
    Yep Castellated nut and split pin
  • ozymax
    ozymax
    you could probably get away with just a thinner nut and the split pin. It's only stopping it from completely un doing and falling off
  • Colstah
    Colstah
    Nails take the place of split pins for me, once the original split pins become unusable.....but I'm not suggesting you do that!
    Actually, despite the reasons listed below, I find it preferable in some ways, 'cos I cut and bend them into more or less a circle, so there are no sharp ends to avoid when cleaning the bike!!
