RPM at 100 km
  • Bashful
    Bashful
    Hi,
    Does anybody know as an estimate, what the RPM would be for these scenarios below?
    96ci stage 1 with oem pulleys?
    103ci stage 1 with oem pulleys?
    I have googled for half an hour and I have come up empty handed.
    I can only asume my cams are stock and on my 96 cube it is showing 2200 RPM at 100 km.  I am trying to determine if my bike has had the 103 kit installed.
    Thank you in advance.
    good luck trying to work it out like that,mabe a lot easier paying for a power run on a dyno
  • Bashful
    Bashful
    yeh, too true mate. I'm itching to pull it apart just to see whats in there.
  • Fritzables
    Fritzables
    This may help: http://www.gearingcommander.com
    I might be way off here if I'm wrong someone please put me straight,
    why would changing a cam change your RPM @ 100Kph,
    I thought changing Cams would only change where your peak torque is at RPM,
    None of the gears have changed, the final drive hasn't changed, so why would the RPM at 100Kph change?
  • ozymax
    ozymax
    correct allide.
    the only things that will change rpm at a set speed are gear ratios, that includes transmission, primary drives, front and rear pulley and over all tire diameter
    edit
    or clutch slip
    You,re not way off Allde , cams or capacity can,t change revs at a certain speed , only gearing .
  • Cv ohhh
    Cv ohhh
    You need a slide rule and compass.divide your ports equal circumference by the amount of spokes on the front wheel.
    Then,count how many spark plugs you have,take that number(should be the squared root of 4?)then multiply that with the amount of spokes on the rear wheel,then,rub a piece of bacon on ya nuts n go play with a pitbull.
    Farkin glad I found this place.ARRRRGGGHHHH,nothin like the internut huh?gahagahagaha
  • Soapbox2627
    Soapbox2627
    I believe 6th gear is only good for 120+KPH.
    as we are the lucky country, our speed limit is 110.
    75MPH (120KPH) on freeways in the States or 85 MPH (136KPH) on the highways (interstates) so the high gear is able to be used properly.
    my 88TC now a 103 has a different rev range now since the rebuild.
  • ryno_0000
    ryno_0000
    I found cruising at 100 I could easily ride in 6th. I never really thought about damaging the box at that RPM.
    Is there any chance of damaging the tranny similar to an overdrive gear?
  • Bashful
    Bashful
    I know Pauly, its a bizarre thing to contemplate. This bloke in the US paid $6000.00 to a mechanic to build his engine after it had shit itself and they are saying the cause of the problem was the bike laboring. I don't believe it otherwise we would have heaps of guys in Australia having these problems and I haven't heard of anyone having any issues.
  • Captain Hook
    Captain Hook
    Most of the Twin cams have a 32 front and a 66 rear pulley. A popular swap is a 31 or even 30 front and a 68 or 70 rear which gives better accelaration.
