2014 Street Glide Fuel Range
  • slup
    slup
    Hi, would anybody like to share how many K's you average on a tank of fuel. My bike has vance and hine dresser duals, monster round slip on mufflers and a heavy breather AC, SE tuner, at the moment the bike has travelled 1400 k's and at best my fuel range is 206 k's this seems way too low. I'm booking the bike for it's first service next week and would appreciate a bit more information just in case I get stuffed around. Thanks in advance for your helpsmiley
  • Deadwood
    Deadwood
    I just recently ran out of petrol (50M from a servo) and my speedo read 379km's which was pretty good going considering its an 09 Road King with a 103 kit, AC etc etc, most if which were riding through the twisties and I'm 130kg.
    206 is way way off.
    350km no probs . Fill ya tank , do 100kms and fill it again , note how much ya put in . 22.7 litre tank , @ 5.5 litres per 100km , 400km should be possible .
  • Damo222
    Damo222
    My '14 Streetglide does 350km+  two up, with a heap of gear ( very heavy, close to maximum allowable weight).
    Reckon i could squeeze 400 out of it. I've only got S&S SPO mufflers on it.
    I'm impressed by how good the economy is....
  • Fe883
    Fe883
    I road tested one on Thursday last week for the day. What a magical bike!
    It had the same amount of K's & i easily got 320K's from it & still have some fuel in the tank. (nearly a 1/4)
    I would of rode the bike till it was empty but had to head back.
    Will be by next bike me thinks.
  • Canetoad
    Canetoad
    Hi,
    I have a 2012 Road king and usually get around 380 to 400klm to a tank, using Caltex 95 vortex, Caltex seems more consistent than any other fuel I have tried.... I fill to the brim just below the fuel cap .... I have V&H monster ovals, stage one with SE tuner and a set of Xied's fitted which actually uses around 5 to 8% more fuel, though if I get to heavy on the throttle it quickly drops to around 350klm. Oh and my bike has done 12500klm since September 2013 when I got it new.
  • Harry28
    Harry28
    I bank on getting around 300 k's 2up out of the stg4 for usually around 16-17 litres, I try to stay in front of traffic.
  • slup
    slup
    Thanks for the input, problem solved, just had the bike for the it's first service, turned the settings for the gauges was in miles not Klms. All the short rides i did on the hot days, silly me all i was doing was topping the tank up at the time thinking the tank must be smaller than last bike.
  • grahamjb
    grahamjb
    Southern Cross to Perth approx. 370km and my 2014 Ultra used 20.7 litres.
    Good stuff doing a 200klm run tommorow about half tank
  • Neale
    Neale
    I get 400 from my 08 flht.
  • Neale
    Neale
  • Neale
    Neale
  • Hoppoz
    Hoppoz
    I get well over 400km on my 2014 Ultra Limited
  • Carmo
    Carmo
    So far I've not done a full tank on the highway cruising along in 6th. I've been doing a lot of stopping and starting around work and the local area. I still manage between 325 and 350 on the same tank when I do get out for longer rides. My bike is completely stock atm
