120r ks
  • chriso
    chriso
    Don't know if it's been done before but  now that the 120rs have been about for awhile and there's a few on here with em, I'm keen to know  if anyone has racked some decent ks up on one without pulling to down changing parts and mucking around with it all the time.
  • chriso
    chriso
    seems they've all disappeared, or nobody done any decent ks on em yet?
  • ozymax
    ozymax
    try in another section maybe.
  • Dutchy Hoogen
    Dutchy Hoogen
    Only got about 18,000kms on mine so far.
  • Ando
    Ando
    around 40 000ks
  • robots
    robots
    Hi,
    Woohooo here we go chriso, just need to put in right bike now man
    Thanks
    Robots
  • thereyougo
    thereyougo
    Nearly 10,000k's
  • Odin
    Odin
    time you sold it then Dutchy Hoogen since you have the wheels off it
  • Dutchy Hoogen
    Dutchy Hoogen
    Well Ben Odin,  I love it to much to sell.  Only 33,000kms now and tires back on. New night Dragons front and rear.  Have not been riding as much lately. But still having fun.
  • chriso
    chriso
    Nearly 10 thous on mine now, goin like the clappers
  • Dutchy Hoogen
    Dutchy Hoogen
    Getting a little bored with mine.  Need a few more pony's. A lot more would be good but not realistic. If my money tree was to grow that would solve it all.
  • chriso
    chriso
    Shave a bit of heads to up comp to 10.7 to better match the 266s.
    A decent tune ( a lot of Cowboys out there in this department) and providing you got decent pipes you be hanging on for dear life LOL
    It's not a huge cost and no need to fuck around changing cams,Pistons etc
  • Ando
    Ando
    17000ks on the 120rx in 13 months, apart from the busted Valve spring and valves seats still running strong on long rides and the quarter mile
  • Dutchy Hoogen
    Dutchy Hoogen
    Mine ran shit until Neville Lush tuned it. He suggested the compression increase aswell. Front head gasket starting to leak a little oil now.  More power maybe closer in the future than I want.
  • Daggs
    Daggs
    Yeah up the comp for a reasonably cheap boost, cam change would be next, both mean retuning though, just whack on a pro charger or turbo mate.... I know you want too :)
  • Lushy
    Lushy
    Show me a cam which will work better without a total head rework. SHOW me , like evidence, back to back both bikes tuned properly with only a cam change. Sorry Daggs, nothing personal, but I have had three free advice calls this week about this subject. What cam is proven to be better? If I can know this I won't have to spend ages on the phone with these guys. I can just say" put this xxxx in and get your guy to tune it".
  • chriso
    chriso
    Lushys post above is exactly what he said to me when I suggested cam change in mine, upping the comp and leaving the 266 in was also suggested to me by him.
    Results of 140 HP speak for them self I think.
  • Dutchy Hoogen
    Dutchy Hoogen
    My heads will have to come off during winter period because the front head gasket starting to leak a little oil. Plus only one exhaust stud left on rear head. Managed to get it to seal but only so I can ride to get through warm weather. I know when exhaust leaks anywhere because back fires when I back off.I don't know how much more can be done to 120r heads but Ill aleast go with Lushy's recommended compression increase. Maybe roller rockers revised spring rates as top end is noisy. Then take it back to Lushy for retune. Done about 33,000km now, not sure how long rings etc should last but time will tell.  Learned to like the CAMs just need to work the gears more. Daggs yours does have more torque than mine under 4500rpm for sure. Id love one of those Big Cube 130plus cube turbo engine but have to win Lotto.  Like I've said before 135 hp starting to feel a bit lame. About another 50 or more ft pounds of torque would be awesome but unrealistic.  I'll just keep dreaming.........
    Managed to fuck seals on my rear shockers on our lovely roads. Front end is shuddering when breaking at low speeds, head stem bearings bit sticky and stiff, front forks and swing arm clunking. So going to be busy boy this winter.
  • Daggs
    Daggs
    It's good for the 120r guys that the stock cams are good performers. They'll be happy to hear that for sure.
    I have no experience with them but just thought that there should be something better than what they come with, stock off the shelf.
    Also I knew that Dutchy was contemplating some headwork.
    Sounds like a bit of work for you Dutchy with the issues you mentioned but you do ride it "spiritedly" lol
  • Dutchy Hoogen
    Dutchy Hoogen
    Hit another huge bump again today one of those you don't see. Heard big crack noise as it bottomed out. Can't find anything obvious wrong. Maybe thats the sound of the shocker with no oil left in it.
