Online: beaglebasher
EPA Notice
  • Sierra1
    Sierra1
    Hi,
    I have recieved an Noise Emission Test notice for my 03 Dyna.
    I have 2" straight through and have been told that I will not be able to baffle them below 94 db.
    I do not have my stock pipes, thoughts?
    I think you need to ask around the forum and shops if you can borrow a set of factory pipes
  • Sierra1
    Sierra1
    Cheers Mate,
    Does anybody from Hawks Nest to Sydney have a set?
  • snoozer
    snoozer
    Best of luck with it, you'd think the EPA would have better things to concern themselves with : (
  • Sierra1
    Sierra1
    It was Smitty, he is such a great Australian!
  • Dutchy Hoogen
    Dutchy Hoogen
    Maybe a look on ebay. Or even for sale on this sight. Gum tree etc.
  • crookneez
    crookneez
    I think I recall someone saying that if you put the standard pipes back on for the EPA test and remove them later, there is a much bigger fine?
    Maybe check the veracity of that out.
    I have a set of OEM mufflers in the shed that yah can borrow. Assumes your in melbourne of course...lol
  • Sierra1
    Sierra1
    All good,
    Dean from Loaded Motorcycles in Kirrawee is on to it.
    Happy Days.
