Online: tussuck
what Pirelli night dragon 180 will fit 08 street bob??
  • jamo
    jamo
    There are 2 diffrent parts, Anyone know if one will fit and if so what one want to put a 180 on the bob
    180/60 B 17 M/C 81H REINF
    180/60 B 17 M/C 75V TL
    http://www.pirelli.com/tyre/ww/en/motorcycle/sheet/night_dragon.html
    Or if you can recomend a better tyre im all ears
  • robots
    robots
    hi,
    i run the first one on my wide glide, they not a true 180mm wide tyre when fitted but overall I happy with them, they will fit on the bob
    look fat as next to gt502 180mm:
    about to go on you beauty gov:
    checked rim for runout and heavy point:
    on:
    so far i on about 6500kms, going okay, probably nudge about 9-10000kms
    just changed front the last couple of days
    thanks
    robots
  • chriso
    chriso
    No flys on you ol mate
    The second one will most likely cost more as its a higher speed rating...ie its rated for 150MPH whereas the top one is 130MPH.
    All things being equal go with the lower speed rated one as you will never get that fast anyway...
  • jamo
    jamo
    cheers for the advice looks like ill be ordering the new one this week
  • jamo
    jamo
    So far so good you can feel the size difference in corners
    If you have a sissy bar you do not need a widening kit from HD
  • berms
    berms
    Hey, thanks for posting that pic, looks great in my opinion.
    When you say you feel the difference in the cornering -- how do you mean? better or worse?
    Thanks
  • jamo
    jamo
    a bit harder to tip in and much harder to get to the edge of the tyre if at all
  • berms
    berms
    Sorry for the multiple posts.... F'ing computers????  laugh
  • peterjs
    peterjs
    if u fit a 170x60x17 back tyre,u cant get a matchn 19in or 21in front,only 17in front,i think night dragons are rubbish,have had them,no good in wet,do u want your bike look better from the back put them on,i just put shinkos sr777 white walls on,corner great,great in wet n dry,160x60x17,i prefer handling than look,an shinkos to me are awesome,hope this helps
  • peterjs
    peterjs
  • peterjs
    peterjs
