Online: HD17, speedzter
Installing Neck Race - Without a tool?
  • 883n Harley Convert
    883n Harley Convert
    Hi guys,
    Got my frame back from powder during the week and have started putting my Dyna back together (slowly) but was wondering whether anyone has installed neck races without having a proper tool? I knocked the top one in with a steel punch and some very delicate taps with a small sledge type hammer but wanted to know whether there is a better way of doing this? I cant be bothered lashing out on a tool when it probably wont ever be used again.  Too many parts are installed to take it to a shop and have them do it now so it's case of doing in the garage?
    Any ideas
    Waz
    it's like you have to clean the hole 1st , get all that coating off, find a bit of round bar that fit's or use a scocket,
    883n Harley Convert
    Thanks DR, I cleaned the neck up with a rotary tool. I'll measure the neck diameter and see if i cant find something to fit
  • Neo Dutch
    Neo Dutch
    Go to Bunnings and get a length of threaded rod, 2 nuts and a couple of big washers.
