Online: HD17, speedzter
Chroming old harley cases?
  • Doc.chop
    Doc.chop
    Hi guys,
    I've just fired up my old 73 custom sportster for the first time is 6 yrs. I'm looking to freshen the motor and well everthing else also. When i brought the bike in '05 it was fully polished but due to a lack of time I want to chrome heads and cases, I was thinking I would powdercoat the cylinders. The bloke who is going to help me with the motor is and old harley guru. he worked alot on high performance sportsters in the 80-90's. He has recomended that I dont do it as the chroming process can warp the cases causing major oil leaks???
    Have any of you had any problems like this?
    I kinda hoping the chroming process has evolved and been refined a bit since he did it...
    Cheers Doc
    pollished aluminium is the best , chrome won't get you home . esp after it starts pelling off ,  1 good way too fuck a Sporty,     are you Greek
  • Doc.chop
    Doc.chop
    No mate not greek...
    I do like the old school look of the polished ally. But im trying to avoid the 8 hrs every weekend I spent in the past polishing it and water stains.
    Cheers Doc
    if your taking  the outer cover 's  rocker boxes ,cam cover etc , not the main engine case's ?,   the acid dip is not good for the cam bushing's , after a while the chrome can peel off manly starting from small stone chip's, if you polish aluminium use kero , no soap , just hose off & rub a little clean oil on for protection , when it's dry its hard to keep clean
  • fizzicist
    fizzicist
    Don't go for chrome, one break in the surface from a stone chip/dropped tool it will be ruined.
    I use silicone spray on my polished aluminium and wipe away excess with a very small cloth that is completely damp with the spray so you're no wiping the silicone off.
    No water stains, does attract a bit of dust by end of the month but it comes off easily with a wash.
  • HogBag
    HogBag
    Chrome will also hold the heat inside the cases so stay with the polished cases. My commando has chromed timing,clutch covers and a few other aluminum pieces around the bike that the PO had done and its flaking off and looks like shit.
