Online: B0nes
SOFTAIL REAR GUARD ON SRORTY
  • Niki
    Niki
    hi, does anyone have info on "how to" get softail rear guard for my sporty, have contacted USA- no response. contacted nsw dealers-no response
  • fizzicist
    fizzicist
    Best bet is a wreckers.
  • 06 Softail
    06 Softail
    Check out one of the site sponsors here "Choppaweeza". Speak to Wayne, his shop is in Richmond I think. Hopefully he might be able to help you out somehow. Good luck, I've never seen a Softail rear guard on a sporty, but think it would look cool.
  • judgelj
    judgelj
    I've seen a fair few and I've always wondered if they were specifically made kits for the sportster or conversions using actually softail fenders
  • Colstah
    Colstah
    I bought an unpainted, after-market bob tail guard, then just drilled and cut as needed to get it to fit '92 Sportster. Don't ask for details, was 20 years ago!! :)
  • terroristone
    terroristone
    Anything can be made to fit. All you need to consider is the width of the guard.
    T1
