2013 Fatboy wheels on 2007 Fatboy
  • lewy
    lewy
    I bought a set of 2013 wheels and front forks from my 07 Fatboy with the intetntion of correcting the offset front wheel.
    Has anyone alse done?
    Is there anything else that I will need or need to know?
    Thanks
    Lewy
  • pat
    pat
    If it had abs the bearings are wider and spacers different. change bearing
    It's coloured orange , was on my Fxdf abs sensor reads special bearing
    Most wouldn't ever be aware of or even notice the slight offset in the front wheel. It doesn't affect handling so it's a fair bit of effort you're going to
  • lewy
    lewy
    Thanks guys. Fatbat it has always annoyed me so while replacing the lower fork legs with a chrome set I thought I would sort it out. Helps fill in my days off
