Online: Lushy
Oil Temp for 2012 103ci Wide Glide
  • tubbytuk2013
    tubbytuk2013
    Hey all,
    My Oil lvel/temp digital gauge is reading around 106 - 119 deg C hot after a normal run.
    Is this temp to high ? Should i stress ?
    Engine gets a little more rattly (tappy) at this temp as well.
    Or is this normal for a 103ci Engine in a Dyna ?
    Cheers.
    Tubs..
    As the oil gets hotter it thins out a bit and does not do as good a job of keeping all those motor noises at bay. Is your temp gauge a HD screw in LED one?
  • tubbytuk2013
    tubbytuk2013
    Yep.. its the Black LED Screw in one from HD.
  • tubbytuk2013
    tubbytuk2013
    Cheers mate..
    1st Harley thats all..
    Im lovin it and i dont want to kill it and have it sit doing northing till it gets repaired.
