Online: Retroman
Best place to purchace a Springer Seat
  • Skippy76
    Skippy76
    I want to change my seat to a springer/spring seat and wanted to know where the best place to purchase one is and also what is the best brand.
    I see that a fair few of you have them on your bikes and i love the look
    if you guys can point me in the right direction it would be great
    2004 1200C
  • 98superglide
    98superglide
    There's a few out there...rich Philips is a good place to start. There is also la rosa, they also do decent solo saddle bags etc. you need to buy a base that bolts on to your frame and is easy to take on or off, otherwise I think you need to weld.
    I think harley do them now too, quite nice to look at but pretty dear too. I like the rich Philips range, some great graphics, different leather styles etc.
    Good luck.
  • MS3368
    MS3368
    Skip,
    I bought mine from the Stealers and was quite excy at a little over $600. The quality and comfort of the ride are excellent though... It is by far the most confortable seat I have tried!
    Mark S.
  • brash
    brash
    Mother Road customs do a nice one.
    http://motheroadcustoms.auctivacommerce.com/
  • jocky
    jocky
    lowbrow customs,thanks to scouser thats where i got mine for my bobber build.
    nice quality couldnt be happier,also depends what you want but here is a pic of mine
    all brackets&springs $390 deliverd
  • HOG50
    HOG50
    There's a nice leather one on Gumtree http://www.gumtree.com.au/s-ad/1041447539
    (My first post here - thought I'd try to help. And no, I'm not the seller.)
  • Trick
    Trick
    I went to rich phillips for mine. Does some nice work.
